Your file is tuned lightly little power !!
Egr on dtc is fap on
Hello mates,
Have a problem with car. The story is some unknown tuner made dpf off,egr off and strange tune but, it doesn't works well.
Car goes ok, no limp mode but smoke like hell, soot level 183% and dtc p2452
With egr have DTC p0400.
Adding 2 files (original and tuned) - zafira.rar
Thanks for help and advices!
Have a nice day everybody!
if you need my help i have experience with that car, contact me on PM
Try and report
The best way of being grateful is touching the button thank
I have the same problem with a meriva a17dt 74kw, ecu D07005Z17DT
NCLMP70T 7058 mpc sh7058. I can not get it out, reset% before each operation, it does not work in swiftec, atr, erase whit dpf pressure and temp disconnected, every time the machine does not regenerate but, clogging rises after 780km fixed reaches 180% and turns on the spy, But the car is fine, no protection and no regeneration. The problem with this ECU is the clogging counter. Can not anyone have managed to block it yet?
pike (5th May, 2017)
ecu is denso my friend... have you ever gone through this kind of ecu?
Only once, Zafira B, with swiftec, before 1 week.
Will see what will happens in next 1000 km...
eculevel (6th May, 2017)
Where I have tried so many. If you want to try out your file, I have lost hope
D07005Z17DT
NCLMP70T
flash.rar
Here You go, my friend. Test and report.
