hello
need help for remove dpf 2008 toyota hiace.
ECU part number 89661-26E80
SW 89663-26603
temperature sensors have damaged
hello
SW 89663-26603
your dpf off which you want
DPF/FAP off, AdBlue off, EGR off, Throttle valve off, Flaps off, DTCs off, Lambda off,
Brayn (5th May, 2017), davinchi19861 (4th August, 2021), kbaloness (5th August, 2020)
pass please ..........
Pass please
Sent from my F3216 using Tapatalk
I have asked 3 times for pass. but you did not send me pass. ok no problem. if you do not give me pass why you make DPF off file post here??
it is a real joke.
as my knowledge this this group for help each others. i not tell you help to each others. it is your choice. but i have help more and i will help that is why i am here.
when i ask help you have post you can help me , but you not give me password. let me ask please why is that?
if you can not help us it is no problem.
if you need money for this file please post here your file Value. someone will reply you
Daniel306 (6th January, 2018)
gitco
however my problem solved. if you need dpf off file tell me i will post here free for you
vanos batam (20th September, 2018)
Good day,
Can you help with Dpf off for hiace???
Denso, Transtron, Hitachi & aftermarket Standalone ECUS
Hello brayn what tool u use to read flash on toyota hilux ecu?cheers
KTAG ? Or other tool ?
does anyone have ktag connection diagram for this ecu ?
ktag do it
