hi. frend not good file.
Hello mates. I need to off DPF, EGR and SWIRL in my car - Vectra C 2005, 1.9 150PS.
There is deleted DPF but software is made not good, DPF is now in emergency burning (blinkink glow plugs indicator) every 8-10 km, DPF is cutted. Since i have this car (since august 2016) there was no any problems, only from one week still emergency burning.
Also, EGR and DPF off and maybe some more power if it is possible?
In .rar there are 4 files readed by BDM100:
1. EEPROM
2. External_flash_Am29BL802C
3. Internal_flash_MPC556
4. All (it is full read by BDM100).
Thanks!
stachu22 (7th May, 2017)
Hello! Which file is corrupted?
does not recognize the flash
Hmm. Here is second read:
and info from OPCOM:
hardware number:81013408
Engine type: Z19DTH
Part number:55205633
Ok, i think my flash can be damaged. I compare it with similar found on the forum, there is another size of file. I try to program new files to my. If you can, make all OFF on these files:
VECTRA.rar
hi friend. does not recognize.
if the driver on the right.
UNABLE TO HELP MATE THERE IS SOMETHING WRONG IN YOUR FILE
Does not recognize my second read and another new files?
Driver is on left side if it is important, it is european version
My file can be broken because DPF should be deleted ok but it is not. There is another file what i found on the forum (6 post) "VECTRAC.RAR". It is also damaged?
HERE IT IS PLEASE TRY AND REPORT
THANKS
ok. I can not solve you problem.
Opel Vectra-C (Original) - A50284).rar
File ok for Dragan.Try now.
hi frend thanks . disconnected all plug.
pass.pm
Vectra-C (dragan elektricar dpf egr off) - A50284).rar
File ready for flashing , cks ok.
If you write direct file from draganelektricar your vectra will not start.
