First help others users, second get help
First at all give the file
CHIPTUNING, ECO-TUNNG CARS TRUCKS BIKES,
EGR OFF, DPF OFF, NOX O2 KAT OFF, SWIRL FLAPS OFF, THROTTLE OFF, MAF OFF
DTC OFF, LIMP HOME MODE OFF!!!
ADBLUE OFF, SCR OFF, ADDITIVE OFF, CNG OFF, SPEED LIMTER ON/OFF/SET
HOT/COLD START
CRC FIX - FULL GENUINE WINOLS FULL CRC / SWIFTEC FULL CRC
TRANSLATE DAMOS ENG
COUNTER FIX - VAG EDC16, EDC17
ORYGINAL FILES DATA BASE
START/STOP ON/OFF
These two codes point to an open circuit with the airmass meter and build-in intake air temperature sensor.
Loose connection maybe? Or a ground problem?
Thanks for helping me.
I've already checked the wires and connector and it looks okay.I checked the bodies connected to the bodywork.Are there other things to look at?Is it possible that PCM should be changed?
PS:I will make a copy of the files later
Someone can guess if ecu already was replace it in the past ? no offence sir...
Full WinOLS user
Custom ENG/GER OLS file for Tune /DPF / SCR / EGR / TVA / VSA / DTC and more...
It has been replaced in the past. What is the problem?
ford focus
