Results 1 to 4 of 4
    Default opel astra 1.9tdci edc16c39 glow plug mod
    Hello friends, i have opel astra 1.9cdti very hard to start when engine is warm. when glow plugs works car starts just fine. Starter reconditioned, new temp sensor installed, injectors checked - no problem.
    I think making glow plugs work for few seconds until temp 70-80 c should solve the problem so i ask for help to mod my file?
    i attach obd read edc16c39
    thanks!
    Aug 2014
    usually it's enough to put some more fuel in starting map.
    try this.
    be aware your file looks partial to me, I attach also complete read.
    Do you have any way to read it in BDM in case of problems?
    Is yours 150 or 120 cv?
  3. The Following 2 Users Say Thank You to lsdlsd88 For This Useful Post:
    bonux (8th August, 2017), reini1976 (20th February, 2023)
    Jul 2013
    Latvia
    lsdlsd88 is right,
    Got some problems with partail reads. Car was not starting anymore. Had to find BDM read - make changes (dpf off, tune or anything) and then write it through OBD2 - all was ok.
    Thanks lsdlsd88, your file cured the problem!
