No one ?
Hi DK member,
I need ori file of these ECU. ECU is Marelli IAW48P
See photo for more info of ecu id.
I can not read the ecu, car doesn't start because immo is blocked. It is an 29F400 eeprom. I mean it is readable with obd ?
Does someone have ori file and can do immo off ?
Read with delphy and DTC is P1612 and P1517
Can someone help me ?
Very thanks!
Kind regards from Belgium
Sedat Garip
Chiptuning Remapping, file service, stage 1 & 2 dyno tested.
Diesel + petrol All cars
Manual Adblue dpf egr Opf tested working solutions
Belgium
With Kind Regards,
Don't forget hit thank button if i helped.
No one ?
Sedat Garip
Belgium
With Kind Regards,
I need more information about the car.
What do you need ?
Car is Peugeot 206 1.1i 60hp from year 2001.
The problem: Car was oke, but the next morning, car doesn't start. I read with Delphy (immo is blocked). I try to learn the key, but is also failed.
I try to read the file with Kess, but gives error 'invalid key', maybe immo is locked that's why i can't read the ecu.
I can only write. So i need original file with do immo off and hope the problem solved.
thanks for you fast answer!
Sedat Garip
Belgium
With Kind Regards,
desolder 29f400 and read
Sedat Garip
Belgium
With Kind Regards,
put ecu id when you try to read
ori file 1.4 benzina iaw 48p2.70 hw 9642423780 sw 9642597689 flas , read eprom
sdtsedat (11th May, 2017)
