send the file to swiftech
your file off dont forget thanks and reputation
report when you upload.
for me work 100%
youssefi201 (10th May, 2017)
thanx freind for your help but lamp stay on and message adblue to low
reset dpf and adblue with scan tool
if that way dont work
refill to minimun the adblue and test it
the adblue level can not be reset when level sensor are damage ! you have to emulate level sensor with one 560-680 ohm resistor !
Full WinOLS user
Custom ENG/GER OLS file for Tune /DPF / SCR / EGR / TVA / VSA / DTC and more...
Faraday (11th May, 2017), youssefi201 (10th May, 2017)
TUNING - DPF Off - EGR Off - ADBLUE/SCR Off - FLAP Off - TVA Off - DTC Off - LAMBDA Off
If I helped you please use button Thanks.
thanx freind but alwys lampe on its unnatural IM TRYING WITH 3 FILE AND SAME PROBLEMEunnatural
Diagnostic no dtc
but lampe in dash blinking and message adblue to loW i tried reset function but no success
yes under driver chair
hi again Ii I wrote the file and after reading the file I noticed that two line not change is what it can be the cause ??????
hi to everybody
somone can help me to make adblue and dpf off on this file?
Numero Hardware: R2AX-188K1-B
Numero Software: R2AX-18881-L
Software di aggiornamento: R2AX-188K2-L
i have light on level adblue
thanks in advance
M.CX7_cat.rarCX7_cat.rar
