Page 3 of 5 FirstFirst 12345 LastLast
Results 31 to 45 of 69
  1. #31
    Dec 2018
    HI there,
    Can somebody help me to solve my UCH clio2 problem? I would pay it via paypal, just PM me. (if you can send me a good UCH for the old one)
    My wife has a 2001 16v 75LE 1.2 clio2 and the UCH sometimes stoppes the index blinker. Very dangerous(!), my kids are inside the car.
    And sometimes the windscreen wipers stops + I hear many relay clicking sounds from the uch box I guess, like an old tram from nineteens.
    My UCH is : G1 V4.1 21 658 964 -5b 26/06/01
    Reading your prev posts, I see I can change it with an N1, or N3? (the car has no clima and only the first windows are electricals)
    Thanks,
  2. #32
    Garage
    Did you try my solution?
    If you have soldering skils you can do it.
    For change uch you must have virgin dump for uch and ecu and renault clip. Or put new used uch and make new keys and make configiration of uch to match you equipment that you have in car.
  3. The Following User Says Thank You to tomo776 For This Useful Post:
    kompleks2 (25th October, 2019)
  4. #33
    Dec 2018
    Hi, can you send me password to unpack your solution? (i don't know what is it)
    What I did today is I resoldered the 40 pin black connector, but got no luck.
    When UCH stoppes the wiper, switching on the blinker starts the rear wiper too, all the time despite it is off.
    I have OBD immo key overide tool from hickleys.com and I bought some cheep remote controller to control the door lock => I guess my UCH has been in bad condition for years
    Can I just replace G1 V4.1 21 658 964 -5b 26/06/01 with a cheap used N2 v4.3 ? My friend is an electrican at Renault saloon in my town, he has tools to reset, copy UCH, and said the new UCH is around 400 british fonts, our car not worth so much.
  5. #34
    Jan 2018
    Germany
    hi
    anybody has pin out for this module ? i resolder everything on the board.
    in my case i can reed with immo tool eeprom data over obd but i can´t read the hole car only airbag answer???
    car is not starting light window wiper and remote work good. starter only work for 2 sec
  6. #35
    Feb 2018
    Default pass please
    [QUOTE = tomo776; 3220718] Problemas e o
    caminhão Não Iniciar, Problema de Janela Elétrica, Luzes Não funcionam etc.
    Carro enlouquecendo e as vezes when rápido Você puxa um Fiação do Trabalho do Carro uch ok, mas ISSO Corrigir ESSES Erros.
    O primeiro é esporádico que o carro não inicia e o problema com o carro elétrico, mas depois não se conecta com o impulso de algum tempo.
    Esta correção se o carro começa a fazer isso sem motivo.
    O trocater de bateria e inverter a polaridade, misture - se.
    E se alguma parte do seu interior estiver queimada por algum motivo. [/ QUOTE]
  7. #36
    Dec 2015
    Spain
    hi tomo please send the passw many thanks
  8. #37
    Mar 2012
    Günzburg/Kayseri
    Pass please
  9. #38
    Quote Originally Posted by tomo776 View Post
    Hi.
    I found something and repair this uch without them come back to me.
    It take me a lot of nerves to find this but I wanna to find what can be done and after that solution I repair more then 10 uch and cars work more then 3 years without problems.
    If someone need this ask on pm for password.
    I use picture from 1 post of mexanico1971 .
    And my picture high res. to see how it`s look after repair.
    Soldering is not my best work but in late nihgt hour when I work this can pass.
    Hi!Send me a pass pleas!
    Thank's!
  10. #39
    einet's Avatar
    this unit cost 150€ on renault
  11. #40
    Jun 2019
    South Africa
    Hi.
    Hi there. New to the forum. I see this is an old post but I am having the same issue. Has anyone been able to find the solution? Any feed back will be much appreciated. Thanx
  12. #41
    mexanico1971's Avatar
    portugal
    Guys !
    Don"t ask for pass in the thread
    Send PM , to who put the files
    Thank"s
    My work is my life ART TECH GARAGE
  13. #42
    McDowell's Avatar
    Feb 2019
    Zamunda
  14. The Following User Says Thank You to McDowell For This Useful Post:
    Meat-Head (11th February, 2020)
  15. #43
    Oct 2013
    Please pass
  16. #44
    pass please. thanks..
  17. The Following User Says Thank You to zefoguete For This Useful Post:
  18. #45
    Feb 2011
    Poland Siedlce
    Hello. Please pass. Thank you very very much.
