Results 1 to 15 of 16
    Feb 2016
    Barking
    Default audi a3 2005-steering angle sensor.....
    hello friends.maybee somebody have same problem like me?
    no faults in esp but esp and steering asistance lamp not go off.........and no power steering............in power stiring 2 faults steering angle sensor and another now not remember properly.write late...........so i teach in esp module angle sensor and in power steering .looks like teach..............but in life data i seen only o.00 not change nothink.i change steering angle foto diods,module.....................but same ..............not changes...................maybee somebody was having same problem?????????thanks iun advance..............where can bee problem?maybeee in gataway?thanks in advance everybody............
    lush29's Avatar
    Oct 2015
    Quote Originally Posted by aidas190 View Post
    Post the exactly faults here. Make full scan and post here
    Feb 2016
    Barking
    in steering asistance 2 faults;02546 steering limit stop 00778steering angle sensor
    autobo's Avatar
    May 2014
    Bulgaria
    You must learn steering angle sensor and steering limit stop and drive the car,then lamp go out
    Feb 2016
    Barking
    hello............my friend itry to do more times from first time i seen that learned ..............but in live data i seen only0.000 and nothink more.........not right answer..........thanks
    autobo's Avatar
    May 2014
    Bulgaria
    when sensor is not learned always will seen 0.00
    Feb 2016
    Barking
    i was changed sensor completly.........................same problem..............hawe anybody any ideas???????????????????????hey strongers where are you now????????????????????i thing maybee problem in getaway??????????????
    Aug 2013
    Try to follow the instructions on this link, sometimes the diagnostic tool does not show the rotation values but the adaptation works equally
    http://wiki.ross-tech.com/wiki/index.php/02546
    Feb 2016
    Barking
    hello ffrriend...........iknow this site........................i folow all instructions,dont worry...........nothink not alive steering asist.............so problem is not in steering angle sensor and not in steering asist...................sorry.wery strange keep gataway ...............i thing reason is in him.........because all comunications goes by them...................thanks
    Feb 2016
    Barking
    DSC00047.JPGhello stongers.............i have and use vas -pc rosstech tool,launch,snapon............in esp no faults.................esp lamp not go off..............and steering asist same................
    in steering asist module 2faults......00778 steering angle sender g-85 and 02546 steering full lock so strongers have any ~~~~en ideas about this ~~~~en car?thanks for understanding.................in this car stupid customer put another car clock.........after this starts this problem............gataway looks like ok.............i try recode with vas...............before steering asist was working...........now working only half power................which module can been
    ~~~~ed after this?thanks
    Dec 2012
    EU
    Try to learn when engine running.
    Sent from my SM-G935F using Tapatalk
    Auto Locksmith,Tuning,Dpf Removal,Dtc Removal,Immo Removal,Ecu Adaptation,Crash Data-Clear.
    Feb 2016
    Barking
    thanks friend.........itry more variants.....................i stuck..................i thing and no have any ideas at this moment.................so sorry...........
  13. #13
    Aug 2015
    Was the pump replaced? If it was then I think it doesn't fit the rack-sensor combo
  14. #14
    Jan 2014
    no gateway,,,,,,,, wont be problem usually u must code esp then basic setting 060. whats the history on car what was done and maybe post autoscan
  15. #15
    Feb 2016
    Barking
    many thanks i try to do it tuesday.............and if its help...........write you back..............sorry not help it.................
