Results 1 to 8 of 8
    Jun 2015
    Default C4 1.6Hdi DPF off, EGR off
    Please turn off DPF and off EGR
    BOSCH EDC16C34
    MPC561/RevC CC_OFF 56/56/20
    :1037375534
    96 53 95 89 80
    96 60 32 41 80
    Top Poster piedepesante's Avatar
    Italy
    Test and report
  3. The Following User Says Thank You to piedepesante For This Useful Post:
    p38 (23rd May, 2017)
    Jun 2015
    Raport: The engine goes 3000 rpm only, errorsP1600, P1613. Something is not good.
    mariusica_boy's Avatar
    Quote Originally Posted by p38 View Post
    BOSCH EDC16C34
    :1037375534
    96 53 95 89 80
    96 60 32 41 80
    Here u go, mate.
    Disconnect connector from egr.
    Pass PM.
    TUNING - DPF Off - EGR Off - ADBLUE/SCR Off - FLAP Off - TVA Off - DTC Off - LAMBDA Off
    If I helped you please use button Thanks.
  6. The Following User Says Thank You to mariusica_boy For This Useful Post:
    Jun 2015
    Thank you Colleague, I will report tomorrow.
    Raport: Everything is fine, no DTC, I'll give the report a few hundred kilometers
  8. #6
    Italy
    File is ok 100% you lose injector coding, wrong writing, you don't wait right time maybe?
    what tool are you using?
  9. #7
    Jun 2015
    FG tech V54 via OBD (China :-) )
    I know that at renault you need to code injectors but at PSA?
    In fact lost the injector codes and ECU configuration.
  10. #8
    Welcome, mate!
