you need tomas the mechanic
HI i have took a look to your file, i??m sorry but your files is horrible... do you know what are you doing????
YOU have touched lot of maps that is not necesary, 80 mg of iq on torque map, pump voltaje just to 51 pedal just 40 and so on.... Probably car is slower now than stock.
You have to read a lot.
Hello, could anyone fix my file? Thank you, buy the file to a professional tuner ?? . The car slowed down
He says that the car has to walk well but the car got worse and can not do anything else.
Nobody can help me
Contact local tuner to do proper job ON THE CAR.
Then you can complain him personally if car not runs as promissed.
You have one of the most easy ecus for start learning on tuning there are a lot of info about your ecu, try to modified your self using brain. I you want to do yourself and learn i can help you.
If not is better to go to a professional tuner
Hello he says that professional tuner, I spoke with him that made me file and said that he can not do anything else that car has to be good and the problem is not his. It's sad to deal with such a person and pay for poor results.
you khow maxxauto profesional tuner
alonedark
I do not understand your question
Already solved the problem of my Audi 4, I asked the other person to make a file and everything went well.
thank you
