Results 1 to 3 of 3
    DK Veteran DjRomeoR's Avatar
    Nov 2011
    Garage...
    Default Espace 2003 year wont start
    Hello.
    I have Tenault Espace 2004 year 2.2 DCi and he wont start.
    1 - Cheked DTC in central electronic only fault 37 - steering lock faulty.
    2 - Tried re-program steering lock with FFFF, but fault code stays.
    3 - Try another steering lock, same fault code 37 (steering lock working perfect lock/unlock all works good).
    4 - Try change another card reader - same.
    5 - Try another Keycard code same car accept cluster on, steering unlocks ,but immobiliser light stays on.
    Maybe someone know were can be problem?
    Nov 2011
    Garage...
    + info
    Could this faulty don't let me start a car?
    1 - SRS unit has few faulty
    2- brake control unit has faulty
    And maybe is bad UCH module ?
    Louislesinge's Avatar
    Jun 2017
    French Jungle
    Maybe I could give some help.
    You mean you've changed card that goes with the central (changed too) and done a virgin lock. Now steering unlocks but red light is still flashing. Correct?
    ECU must be virgin again too because it has the original code. (Antitheft chain is: card, central unit, steering lock and ECU).
    If SRS is faulty because of a crash recorded, you need to check the ECU an even no fault is registered, erase faults.
    Regards,
