Results 1 to 15 of 21
    ecumix's Avatar
    Apr 2014
    Default Zafira 1.9 dpf off issue soot stop on 184 %
    Hello i need advice or solution i have zafira 1.9 150 ps after read /write by obd or bdm soot dpf start 510% and about 10 min stop 184%
    so car still grow up oil can someone have this case its difficult to resolve .
    After write orginal file soot its ok .
    aem's Avatar
    Jun 2014
    snowboarding on the mountain
    this is bdm read?
  3. The Following 2 Users Say Thank You to aem For This Useful Post:
    ecumix (28th May, 2017), mariusica_boy (28th May, 2017)
    ecumix's Avatar
    Apr 2014
    Default zafira soot problem
    Yes bdm read by ktag
    aem's Avatar
    Jun 2014
    did you reset all before writing?
    ecumix's Avatar
    Apr 2014
    yes every time
    mariusica_boy's Avatar
    Quote Originally Posted by ecumix View Post
    Your file dpf off tested many time and work 100%
    Pass PM.
    TUNING - DPF Off - EGR Off - ADBLUE/SCR Off - FLAP Off - TVA Off - DTC Off - LAMBDA Off
    If I helped you please use button Thanks.
  8. The Following User Says Thank You to mariusica_boy For This Useful Post:
    ecumix (29th May, 2017)
  9. #7
    ecumix's Avatar
    Apr 2014
    tkanks so much
    mariusica_boy i tested ans report .
  10. #8
    ecumix's Avatar
    Apr 2014
    Both file the same soot grow and less to 184%
  11. #9
    aem's Avatar
    Jun 2014
    DID YOU CUT FILTER?
  12. #10
    ecumix's Avatar
    Apr 2014
    Yes filter cut but remember when i write orginal file soot caclulate ok
    Crazy case
  13. #11
    aem's Avatar
    Jun 2014
    i am sure solution from my partener mariusica is 100% ok....
  14. The Following 3 Users Say Thank You to aem For This Useful Post:
    AVDigitale (9th February, 2019), ecumix (29th May, 2017), mariusica_boy (29th May, 2017)
  15. #12
    ecumix's Avatar
    Apr 2014
    I know . ..I know but i try find solution
  16. #13
    mihaiservice's Avatar
    http://www.quick-tuning.com
    the latest calibration file for Opel cars its have such trouble,such file i`snt have any dpf off switch !
    to bypass dpf you have to use "reversed strategy" !
    Full WinOLS user
    Custom ENG/GER OLS file for ​ Tune /DPF / SCR / EGR / TVA / VSA / DTC and more...
  17. The Following User Says Thank You to mihaiservice For This Useful Post:
  18. #14
    ecumix's Avatar
    Apr 2014
    Maybe the last one solution
  19. #15
    Apr 2016
    try this0281017064.rar
