Results 1 to 3 of 3
    Bosna
    Default Fiat Ducato 2.3 JTD P0638 and LIMP throttle valve
    Hello to all !
    Fiat Ducato 2.3 MJET, need to remove Throttle (P0638) and LIMP.
    ECU EDC16C39_0 281 015 576 SW 1037501111
    Thanks in advance
    mariusica_boy's Avatar
    Quote Originally Posted by mvekaz View Post
    Hello to all !
    Thanks in advance
    Your file TVA off.
    Disconnect connector from TVA.
    Pass PM.
    TUNING - DPF Off - EGR Off - ADBLUE/SCR Off - FLAP Off - TVA Off - DTC Off - LAMBDA Off
    If I helped you please use button Thanks.
  3. The Following 5 Users Say Thank You to mariusica_boy For This Useful Post:
    konq100 (28th May, 2017), mihaiauto (14th September, 2019), morgano (29th May, 2017), mvekaz (29th May, 2017), pike (29th May, 2017)
    Senior Member sazimam11's Avatar
    Jan 2012
    Praha, Czech republic
    Usually a stuck butterfly because of rust on the actuator shaft. To clean - disassemble it completely, clean and grease and use a suitable seal makes the flap work well again. Did it right yesterday.
