Page 1 of 3 123 LastLast
Results 1 to 15 of 33
    Top Poster Sicilian's Avatar
    Mar 2008
    Default Guide to install Crossepg with Gemini enigma2 images - 7 day Sky EPG
    This guide is based on a Satellite Enigma2 Dreambox with latest Gemini image installed.
    Dreambox must have a HDD installed although a DM7025 can be set to use a CF card for the epg.
    1. Transfer crossepg-enigma2_0.3.2-svn-33_mipsel.ipk to /tmp/
    2. Using blue panel file manager navigate to /tmp/, then highlight crossepg-enigma2_0.3.2-svn-33_mipsel.ipk and press green button to install.
    3. Using you favourite ftp program navigate to /usr/bin/ and transfer enigma2.sh to your desktop.
    4. Now again using your favourite ftp program navigate to /usr/crossepg/ and copy crossepg_epgmove.sh to you desktop.
    5. Using a unix compatible editor such as crimson editor attached edit enigma2.sh as follows: -
    Under #Scripte copy this line /usr/crossepg/crossepg_epgmove.sh start
    So it should be something like this: -
    PHP Code:
    #Scripte
    /usr/script/syslogd_script.sh restart
    [ ! -/proc/fs/nfsd/exports ] && /usr/script/nfs_server_script.sh start
    /usr/script/inadyn_script.sh start
    /usr/script/httpd_script.sh start
    /usr/script/djmount_script.sh start
    /usr/script/ushare_script.sh start
    /usr/script/crond_script.sh restart
    6. Again using a unix compatible editor edit crossepg_epgmove.sh, edit the paths to suit your image, but with Gemini images it should look like this: -
    PHP Code:
    #!/bin/sh
    HOME=`echo $0 | sed "s/crossepg_epgmove\.sh//"`
    if [ -
    "$HOME/crossepg.config" # if configuration exist
    then
        DBROOT
    =`cat $HOME/crossepg.config | grep db_root= | sed "s/db_root=//"`
    else
    # else default path
    DBROOT="/media/hda1/crossepg"
    fi
    if [ -"$DBROOT/ext.epg.dat" # try on configuration path
    then
    echo copying ext.epg.dat from $DBROOT
        $HOME
    /crossepg_epgcopy "$DBROOT/ext.epg.dat" /media/hda1/gemini.epg.dat
    elif
    [ -"/media/hda1/crossepg/ext.epg.dat" # if we have a bad path try with default path
    then
    echo copying gemini.epg.dat from /media/hda1/crossepg/
    $HOME/crossepg_epgcopy /media/hda1/crossepg/ext.epg.dat /media/hda1/gemini.epg.dat
    else # no epg found
    echo ext.epg.dat not found
    fi
    7. Ftp your edited engima2.sh from your desktop back to /usr/bin/
    8. Ftp your edited crossepg_epgmove.sh from your desktop back to /usr/crossepg/
    8. Reboot your dreambox.
    9. Once rebooted goto Menu and you will now see Crossepg in Setup, so press Menu>Setup>Crossepg and adjust settings to suit. You can set to update daily & use CF card for epg if installed.
    10. Press Green button for plugins, select Crossepg. Dreambox will now switch to hiphop music channel and update, then automatically switch back to tv channel once updated. At the end of the process the dreambox will reboot.
    11. Enjoy 7 days worth of EPG
    Tools Crimson editor and Crossepg attached.
    D I S C L A I M E R My right to post information is protected under the rights for freedom act. In all instances, information discussed here on my posts are either hypothetical in nature, out of general curiosity, common knowledge, public knowledge, or role-play. Any use of the collective descriptions and shared knowledge from any of my posts are at the sole discretion of the reader. I am not responsible for what you do with it.
    Mar 2008
    @ Mods feel free to make this a sticky This is a hell of a lot easier to setup & run than E2_loadepg.
    May 2008
    South Wales
    cant seem to get this to work on gemini 4.4 on dm8000
    anyone got it working?
    im using blackhole v11 at the mo but would love to try gemini again
    epg seems to download and parse then reboots and goes back to the channel im watching, but no data on my tv lists
    Member theobserver's Avatar
    Quote Originally Posted by shirehorse99 View Post
    13deg works perfect but 28deg never does....... don't know why
    May 2008
    South Wales
    thanks for that - havent tried 13e yet - i will give it a go over the weekend
    cheers
    Mar 2008
    Have you followed the instructions to the letter?
    Once installed did you press menu > setup > crossepg & configure it?
    V.I.P. Member dctyper's Avatar
    Jun 2008
    according to their website it supports cable. do i use the same instructions here?
    Wavefield Ds 55cm at 13E 19E and 28E receiving everything out there on 2 dm800hd
    previous life dm800hd and 500c on cable screw you nag3
    Mar 2008
    Quote Originally Posted by dctyper View Post
    I dont think its supports cable uk.
    Jun 2008
    has anyone tried cus it does say so. mmmmm im just not that confident when it comes to writing code
    DK Veteran on_the_jazz's Avatar
    Jul 2008
    Tried this on my DM800. Got to the reboot stage but it never rebooted. Kept trying and eventually had to reflash
    May 2008
    Very Strange, same happened here with gemini 4.50
    ive got this working fine and epgs all listed for 7 days. I do however see that it DOES NOT reboot once the script is run. Any idea why? Without the reboot the epg doesnt update so i would have to manually reboot to get it to update each day. Is there a fix for this?
  13. #13
    Mar 2008
    Quote Originally Posted by deankanonik View Post
    What image are you using? I noticed the same thing on the latest Gemini image. I then went back to an older image and it re-booted ok.
  14. #14
    I use the latest gemini (4.6)!!
  15. #15
    There is nothing happens after running plugin. Progressive bar in right low corner and dream doesn't reboot after plugin complete. After manual reboot only current and next programm in EPG. Any suggestions?
