Results 16 to 30 of 33
Threaded View
    Top Poster Sicilian's Avatar
    Mar 2008
    Default Guide to install Crossepg with Gemini enigma2 images - 7 day Sky EPG
    This guide is based on a Satellite Enigma2 Dreambox with latest Gemini image installed.
    Dreambox must have a HDD installed although a DM7025 can be set to use a CF card for the epg.
    1. Transfer crossepg-enigma2_0.3.2-svn-33_mipsel.ipk to /tmp/
    2. Using blue panel file manager navigate to /tmp/, then highlight crossepg-enigma2_0.3.2-svn-33_mipsel.ipk and press green button to install.
    3. Using you favourite ftp program navigate to /usr/bin/ and transfer enigma2.sh to your desktop.
    4. Now again using your favourite ftp program navigate to /usr/crossepg/ and copy crossepg_epgmove.sh to you desktop.
    5. Using a unix compatible editor such as crimson editor attached edit enigma2.sh as follows: -
    Under #Scripte copy this line /usr/crossepg/crossepg_epgmove.sh start
    So it should be something like this: -
    PHP Code:
    #Scripte
    /usr/script/syslogd_script.sh restart
    [ ! -/proc/fs/nfsd/exports ] && /usr/script/nfs_server_script.sh start
    /usr/script/inadyn_script.sh start
    /usr/script/httpd_script.sh start
    /usr/script/djmount_script.sh start
    /usr/script/ushare_script.sh start
    /usr/script/crond_script.sh restart
    6. Again using a unix compatible editor edit crossepg_epgmove.sh, edit the paths to suit your image, but with Gemini images it should look like this: -
    PHP Code:
    #!/bin/sh
    HOME=`echo $0 | sed "s/crossepg_epgmove\.sh//"`
    if [ -
    "$HOME/crossepg.config" # if configuration exist
    then
        DBROOT
    =`cat $HOME/crossepg.config | grep db_root= | sed "s/db_root=//"`
    else
    # else default path
    DBROOT="/media/hda1/crossepg"
    fi
    if [ -"$DBROOT/ext.epg.dat" # try on configuration path
    then
    echo copying ext.epg.dat from $DBROOT
        $HOME
    /crossepg_epgcopy "$DBROOT/ext.epg.dat" /media/hda1/gemini.epg.dat
    elif
    [ -"/media/hda1/crossepg/ext.epg.dat" # if we have a bad path try with default path
    then
    echo copying gemini.epg.dat from /media/hda1/crossepg/
    $HOME/crossepg_epgcopy /media/hda1/crossepg/ext.epg.dat /media/hda1/gemini.epg.dat
    else # no epg found
    echo ext.epg.dat not found
    fi
    7. Ftp your edited engima2.sh from your desktop back to /usr/bin/
    8. Ftp your edited crossepg_epgmove.sh from your desktop back to /usr/crossepg/
    8. Reboot your dreambox.
    9. Once rebooted goto Menu and you will now see Crossepg in Setup, so press Menu>Setup>Crossepg and adjust settings to suit. You can set to update daily & use CF card for epg if installed.
    10. Press Green button for plugins, select Crossepg. Dreambox will now switch to hiphop music channel and update, then automatically switch back to tv channel once updated. At the end of the process the dreambox will reboot.
    11. Enjoy 7 days worth of EPG
    Tools Crimson editor and Crossepg attached.
    D I S C L A I M E R My right to post information is protected under the rights for freedom act. In all instances, information discussed here on my posts are either hypothetical in nature, out of general curiosity, common knowledge, public knowledge, or role-play. Any use of the collective descriptions and shared knowledge from any of my posts are at the sole discretion of the reader. I am not responsible for what you do with it.
