Results 1 to 5 of 5
    Default 123d looking for original file 1037509476
    As with BMW software number is not enough to find the right original file, attached you'll find the modified one I read from the car.
    I have a similar original file that I used for understanding that's a really bad job (almost every dtc is off) but I would like to start from an original file for the new mod.
    123d_vecchia.zip
    Jun 2016
    check this dump
    Aug 2014
    here your ori (OBD read).
    mod is not that bad, torque limiters are still there and duration is ori, I've seen much worse LOL
  4. The Following User Says Thank You to lsdlsd88 For This Useful Post:
    ayllon308 (11th February, 2018)
    Quote Originally Posted by lsdlsd88 View Post
    In my opinion DTCs table lined can be just done by an idiot
    Aug 2014
    likely done from an idiot sensor-removing software and not spotted by the so called tuner using ECM
