link is dead allready
I'll put it in the correct section...
Any of our Illustrios members have or can unlock Rosfars laest software for R250s/R260s...Look like a dongle may be required... Or an In and out code...(and yep they are clones)...But they work with the older software supplied...3800 euros..300$..its a no brainer....Even if they only work once .. the are paid...
Loads of thanks in advance of course..
http://rapidshare.com/files/291139846/disk1.zip.html
hello there someone gave me a cloned rosfar the other day i'll upload the software i got with it tomorrow
cheers
scooby99
here you go ROSFAR 3000 sw hope this helps you
RapidShare: 1-CLICK Web hosting - Easy Filehosting
cheers
scooby99
Thank-you mate ..but that is the same SW that came with mine ..7.2....I downloaded the latest version ..9.6 i think from Rosfars site...(mistake ) when I installed it ,it looked great Options to read and save dump.. lovely... But it overwrote 7.2... Which was fine if it worked ..On Examining it closer ..looks like it was looking for a dongle ..in and out code ... (obviously a Plant by Rosfar to get you to fcuk your copied software up ...)And it must write to the registry ..cos you cannot intall it a second time ..goes through the motions ... but launches ..version 7.2...even after you've uninstalled it ...Maybe some one will crack the new version ... I live in hope...thnak-you again mate...
hello
have you got the same cloned rosfar that i have ? but when you update the software it looks for a dongle in the rosfar machine then has a server check to see if it's an original
cheers
scooby99
Looks like it mate.... Don't update software... Use the one they sent you .. I have done four clusters in the past week... All worked...(a bit of ~~~~ing about with the last one ) but they all changed... Made a monkey.. with an outlay of 90$.. Don't care now if it spontainiously ignites...
I got the CAS3 programmer as well.. Having a few probs with it..(sods law eh!)..but will persivere with it ...
