Results 1 to 9 of 9
Thread: FRF Flashing
    Croatia, Zagreb
    Default FRF Flashing
    Hello.
    Could someone please tell me if i write frf file on unlocked ECU will it get locked again?
    Car is Touareg II 4.2TDI (EDC17CP44)
    HW: 7P0907409
    SW: 1037508277
    WV Software Number: 0007
    It is TProt (V7) unlocked (with MPPS Tricore Boot)
    I have attached frf file. Can someone please tell me is this correct file to flash, and can i flash this file with Vag Can Pro?
    Also if anyone can decrypt this file to BIN?
    Thank you very much!
    FL_7P0907409___0007.zip
    ecumix's Avatar
    Apr 2014
    Here you file bin but.....
    hw:7P0907409
    sw:1037511931
  3. The Following User Says Thank You to ecumix For This Useful Post:
    kroksy2101 (31st May, 2017)
    Croatia, Zagreb
    Thank you for converting file.
    So this file is not compatible with my ECU, or if i flash this file it will update software to 1037511931?
    Once again THANKS!
  5. The Following User Says Thank You to kroksy2101 For This Useful Post:
    moffo (1st June, 2017)
  6. #4
    Hello if you flesh with frf your ECU wil by locked agin and frf fail make sw update if you neead som odx for this car send my SW number I will help you
    Croatia, Zagreb
    Hey skiba!
    Thanks for reply!
    If i convert this frf file to odx, then i can update ECU SW, and ECU will not lock?
    ECU HW number is 7P0907409, and SW number is 1037511931. There is also WV software number that is 0007.
    Thank you man!
  8. #6
    Croatia, Zagreb
    Quote Originally Posted by skiba View Post
    Hey skiba!
    Thanks for reply!
    ECU HW number is 7P0907409, and SW number is 1037511931. There is also VW software number that is 0007.
    Thank you man!
  9. #7
    Croatia, Zagreb
    Anyone have solution for me?
  10. #8
    Croatia, Zagreb
    Forgive me if i am boring you people.
    I really need OBD original file for this ECU's that will not tuner protection lock it again. I cannot OBD read it with MPPS. I am getting file is corrupt when MPPS reaches 100% of reading.
  11. #9
    Aug 2018
    thanks friends since there is some frf file vag nr.3T1 920 841 M .Thanks
    Poslano sa mog BV9000Pro-F koristeći Tapatalk
