Results 1 to 10 of 10
    koolstuff's Avatar
    Nov 2015
    Dakar (Senegal)
    Default DTC Removal On SID 807 Please Need Help
    Hi Buddies
    I need a complete DTC removal from the bin file of an ecu Siemens SID 807, Any help will be really appreciated.
    DTC P2137 P0228 P2127
    koolstuff's Avatar
    Nov 2015
    Dakar (Senegal)
    it's been two weeks now i tried to remove those DTC but still no luck
    Aug 2013
    Avete gi? provato in quel modo?
    It seems the accelerator pedal to be replaced
    koolstuff's Avatar
    Nov 2015
    Dakar (Senegal)
    i have changed it already but until now the car can't go above 3000 rpm, i have checked all the wiring from the BSI, BCM, ECU, all seems to be OK
    mihaiservice's Avatar
    http://www.quick-tuning.com
    Even with dtc off your car can`t go over 3000 rpm !
    Full WinOLS user
    Custom ENG/GER OLS file for ​ Tune /DPF / SCR / EGR / TVA / VSA / DTC and more...
    koolstuff's Avatar
    Nov 2015
    Dakar (Senegal)
    mihaiservice so can you tell me what is the problem? is it in ECU or in car itself? Can you please share your knowledge?
    The reason for limp mode are:
    P0228 - Accelerator pedal signal 2 fault : Voltage too high
    P2137 - Accelerator pedal signal monitoring fault : Consistency between the two pedal sensor signals
    Full WinOLS user
    koolstuff's Avatar
    Nov 2015
    Dakar (Senegal)
    But i have change the pedal twice, but still car is not going above 3000rpm
    rm23's Avatar
    UK
    wiring problem or ecu inside...
    koolstuff's Avatar
    Nov 2015
    Dakar (Senegal)
    Maybe Ecu, i have checked all the wiring.
