Results 1 to 4 of 4
    Apr 2016
    uk
    Default Vectra c 2004 2.0dti injection pump psg16 swap
    I have a problem with my vectra 2004 2.0 dti . Must change the injection pump psg16.the code on the pump is 0470504216.I look for it online and is very hard to find or very expensive.Can I change it with another one but different code? Or can I read flash and clone it on a pump with different code?
    Thank you
    Inviato dal mio HTC One utilizzando Tapatalk
    DK Veteran mariazo84's Avatar
    yes you need carprog
  3. The Following User Says Thank You to mariazo84 For This Useful Post:
    comizelu (1st June, 2017)
    Apr 2016
    uk
    Carprog8.21 clone,xprog and mpps .. I can read flash.I don't think is a problem but I need to know if I can swap it with another one not having the same code or clone it on another one not having the same code.
    Thank you
    lush29's Avatar
    Oct 2015
    Thank you
    Just pin code is all you need. Car prog should be fine
  6. The Following 2 Users Say Thank You to lush29 For This Useful Post:
    comizelu (2nd June, 2017), satalightmad (24th June, 2017)
