You need read immobox for pincode
Key programming is manual
Good evening mates,
Some info if possible...
I have this Ford Ranger 2007 with 8C keys and all key lost situation....
I've tried making keys on 95320 of ecu with Tango but i'm getting error P0607 error in ecu and immo light won't light at all !! Tango won't make key to this ecu but it gave me the Pin Code thankfully....
So , i programmed the original file to the ecu,,, immo light came back on ,,, no P0607 but i wanna program 2 new keys to the car now..... I've tried avdi , Focom , DIS without luck ,,,
Can someone suggest if there is a manual procedure for this one ? I've tried ignition ON + OFF 5 or 6 times but then immo light WON"T light fast........
Would appreciate some help ,,, thanks in advnace
I also have this problem, manually do not enter the procedureRanger_Immo_Procedure.pdf
frappes (24th November, 2021), i_shot_the_sheriff (4th June, 2017), kyawkyaw (10th June, 2017), lanefi (15th May, 2019)
Mate , your procedure works 100% !!!!
Only tricky part is entering the programming mode! I managed to get it done like this:
1) Get in car , insert a not programmed key in ignition and turn to ON position for 2 seconds
2) Set key to Lock position ,, wait 1 second (hear a click)
3) Get key out and in 5 times
4) See the immo light blinking fast ,,,, and you know the rest .....
Thanks again for the help ,,, car works like a charm ...
Is it possible to put a used (locked) 8C into the immo dump?
after that will start the car?
Can somebody help me?
yes can be reused
