Results 1 to 7 of 7
    i_shot_the_sheriff's Avatar
    Nov 2008
    Default Ford Ranger 2007 8C {ALL KEY LOST}
    Good evening mates,
    Some info if possible...
    I have this Ford Ranger 2007 with 8C keys and all key lost situation....
    I've tried making keys on 95320 of ecu with Tango but i'm getting error P0607 error in ecu and immo light won't light at all !! Tango won't make key to this ecu but it gave me the Pin Code thankfully....
    So , i programmed the original file to the ecu,,, immo light came back on ,,, no P0607 but i wanna program 2 new keys to the car now..... I've tried avdi , Focom , DIS without luck ,,,
    Can someone suggest if there is a manual procedure for this one ? I've tried ignition ON + OFF 5 or 6 times but then immo light WON"T light fast........
    Would appreciate some help ,,, thanks in advnace
    lion0304's Avatar
    Oct 2014
    You need read immobox for pincode
    Key programming is manual
    szengen's Avatar
    Jan 2017
    Poland
    Default ranger 8c
    I also have this problem, manually do not enter the procedureRanger_Immo_Procedure.pdf
  4. The Following 4 Users Say Thank You to szengen For This Useful Post:
    frappes (24th November, 2021), i_shot_the_sheriff (4th June, 2017), kyawkyaw (10th June, 2017), lanefi (15th May, 2019)
    Nov 2008
    Mate , your procedure works 100% !!!!
    Only tricky part is entering the programming mode! I managed to get it done like this:
    1) Get in car , insert a not programmed key in ignition and turn to ON position for 2 seconds
    2) Set key to Lock position ,, wait 1 second (hear a click)
    3) Get key out and in 5 times
    4) See the immo light blinking fast ,,,, and you know the rest .....
    Thanks again for the help ,,, car works like a charm ...
  6. The Following 2 Users Say Thank You to i_shot_the_sheriff For This Useful Post:
    lion0304 (18th December, 2019), szengen (4th June, 2017)
  7. #5
    Oct 2017
    Is it possible to put a used (locked) 8C into the immo dump?
    after that will start the car?
    Can somebody help me?
  8. #6
    whiskeyman's Avatar
    Dec 2010
    where men are men and women eat their babies
    yes can be reused
  9. #7
    Jul 2017
    Quote Originally Posted by i_shot_the_sheriff View Post
    Will really apperciate if you expounded on the procedure after step 4 above.
