Results 1 to 2 of 2
    Default HELP (NO CA FOUND)
    Hi all.
    I'll try and keep this short.
    I have a DM800 HD SE A8P (Clone) I've been flashing various images into the box over the last week or so without any problems.
    I then found that images that I had previously flashed into the box no problem were coming up with the "INVALID" (Or Old Version) message.
    I looked at the device information tab on the web interface and noticed that the bootloader version had gone down to an earlier version originally it was version 84
    I can't remember the number of the earlier version to which it had changed but after a little homework I thougth that this must be the problem.
    I then tried to flash the version 84 bootloader into the box and ended up with the dreaded "R01 NO CA FOUND" message on the front display.
    After some messing around I have managed to communicate with the box using Dreamup.
    I can get Dreamup to the point were it says "BOX IS NETWORKED IN HTTP MODE" but if I attempt to flash an imagine into the box it just goes to "Calculating Checksum" and stays there.
    Please someone tell me that I can recover this box and that I haven't turned it into a doorstop.
    Any help and advice would really be very much appreciated.
    Thank you and regards, The Soulman.
  2. The Following User Says Thank You to soulmandave For This Useful Post:
    toysoft (5th June, 2017)
  3. #2
    toysoft's Avatar
    Nov 2008
    It seems fixed, If I am not wrong now ;o)
    TS
