No one knows Torque limiter addresses for idle and drive? :/
]Hello, i want to do Popcorn/Hard Cut Limiter on my e60 530D EDC16C31..
so i have read some posts and learned that, its hard to make proper popcorn on edc16 ecus... its much easier on edc15.. so i have seen some videos on youtube, same car with same ecu had popcorn.. so i liked it
so i want to do it myself.. what i must change? only TL maps? and tell me addresses for maps which i must edit
P.S when car is in P or N gear rev limit is 3997 RPM... if i edit values of 4000RPM, i think it may have problems while driving i need to make hard cut limiter on both maps (while gear is in P or N and when gear is in Drive )
i think i talked too much sorry for that..
this is ecu, hw and sw numbers
Bosch
EDC16.A0
1037361890
1037390905
Thanks...
I hope someone will help me
Best Regards 8-)
its quite easy, stationary torque on this car is the one which has 0 nm from 4000 rpm to the end, toque limiters use to be together on the dump, for pop corn just change iq (nm on this ecu) in a short number of rpm to 0 on TL maps..
hope it will help you.
JuniorTuner (9th June, 2017)
pashkutis (26th August, 2019)
If you are not able to find rpm axle from tl maps... i think you should look for a tuner who are able to tune right your ecu.
Guessing he's had his free tune by now and left the building....
Junior, upload ori file it will be easier for all of us to do someone for u then explain..
If i help u, please use thanks and reputation button..
on forum i always help for free, outside forum if u need quickly and good file service contact me on skype..
