    agstur's Avatar
    Aug 2012
    Plovdiv
    Default Volvo V40 Pedestrian Crash
    can you help me to clear this crash data from pedestrian unit!The SRS unit is from Volvo V40 with P31429510 number!And the chip is Infineon XC2361-72F!
    I remove allready the crash data,but the problem with the Pedestrian data is still theare!
    Thanks,in advance!
    agstur's Avatar
    Aug 2012
    Plovdiv
    Nobody even try!?
    dragon100's Avatar
    Jan 2012
    From land of milk and honey
    Try and report.
    Best regards.
    Dragon
  4. The Following User Says Thank You to dragon100 For This Useful Post:
    agstur (21st June, 2017)
    agstur's Avatar
    Aug 2012
    Plovdiv
    Hello, it's been a huge mistake when I uploaded the file!
    Instead of Pedestrian crash, I've uploaded the crash from srs unit! So now this is the real file from the Pedestrian Unit!
    Please if you can try to clear this crash too!
    Thanks!64kb infineon 2361A-56Fcrash Pedastrian inside.rar
    dragon100's Avatar
    Jan 2012
    Try like this, clear errors, switch ignition off for 10sec, switch ignition on, clear errors again.
    Best regards.
    Dragon
    agstur's Avatar
    Aug 2012
    Plovdiv
    Hello!
    It does not work !
    Except all errors now i have a new one! Control Unit Configuration - Incompatible
