Results 1 to 12 of 12
    Feb 2017
    Default Astra H easytronic help please
    Hi mates,
    Please i need TCM good files for both flash and eeprom for 2007 opel astra H motor Z16XER
    Thanks in advance,
    Best regards.
    Feb 2017
    I have sent the clutch actuator for repair and it came back yesterday but still not work...they have only changed the actuator motor brushes but they told me that they can not repair the TCM or even virginize it.If some body have good files for both flash and eeprom i may give it a try so it may work...
    Feb 2017
    Hi again,
    I have scanned the car one more time and i found some important issue that it could be the reason for all of this mess..
    1.engine oil life time is 0 and the oil status really bad.
    2.when i start the car from the start relay the car starts good and the motor speed is around 800 RBM which is normal but the strange issue is that the VEHICLE SPEED...it is around 98km/h on idle speed and when accelerating it reaches up to 400km/h also the cars is stand still...!!!
    BTW i have no crankshaft or camshaft faults on ECM
    So mates....what do you think?Any idea is much appreciated.
    Thanks in advance.
    keturi's Avatar
    Oct 2010
    Lievatu
    Take Global TIS and reflash TCM, ECM, ABS first. After you will see if trouble still exist.
  5. The Following User Says Thank You to keturi For This Useful Post:
    ecu repair (13th June, 2017)
    Feb 2017
    Thank you mate for your reply.I already tried an other ECU but the problem still the same.I am still looking for good files for TCM hopping that somebody may share....
    Thanks again,regards.
    Feb 2017
    BTW,i there are no faults codes except the fault code on ecu p1700(service vehicle soon request from TCM) and P1735 on TCM(gearbox parameters not learned)...and when i try to learn the parameters the learning goes good with all gears 1,2,3,4,5,R and when op come asks to star the car it does not start and still have F on display so at this point gears synchrorization fails and the procedure stops there ....i still need to find out where the vehicle speed is coming from while the vehicle is stopped and only motor is running....
    Feb 2017
    I have just removed the plug of ABS and put it back again so vehicle speed come back to zero...it is normal now but i am still stuck with the issue of gear parameters learning...i still need those files for TCM....
    Apr 2016
    Hi, I am struggling with the exact same problem in my Astra easytronic 1.6 2005. Help needed, Please.
  10. #9
    vasko's Avatar
    Nov 2011
    Gotze Delchev
    post tcm number 0132900008 example
  11. #10
    Apr 2016
  12. #11
    vasko's Avatar
    Nov 2011
    Gotze Delchev
    Default easytronic
    try and report
  13. The Following 3 Users Say Thank You to vasko For This Useful Post:
    adeltech (22nd January, 2022), eldani33 (12th July, 2023), gogoli (1st September, 2022)
  14. #12
    Apr 2016
    I will report the results as soon as possible. Thank you for you response.
