Results 1 to 9 of 9
    bobolin4o's Avatar
    Bulgaria, V. Tarnovo
    Default Fiat Ducato speed limit...
    Hello fellows!
    I need to set speed limit at 100 km/h in this dump...
    Any help is welcome!
    dominik.m's Avatar
    Jun 2009
    POLAND
    Hi. Try this file if You want.
  3. The Following 2 Users Say Thank You to dominik.m For This Useful Post:
    bobolin4o (13th June, 2017), kinketotua (13th June, 2017)
    bobolin4o's Avatar
    Quote Originally Posted by dominik.m View Post
    This was my first attempt - not working...
    Someone else?
    May 2015
    I think you can do this diagnostics
    If you need to reduce the limit
    But if you need to increase the limit then just reflash ECU + BSI
    IF I HELP Don`t forget to use Thanks button and reputation
    Aug 2012
    Quote Originally Posted by bobolin4o View Post
    Someone else?
    check adress 782da 4 x 30000 set it to 10000
    also 794b8
    i?m not sure but u can test
    Tuning Cars and Trucks, Immo off , DTC delete, DPF off
    bobolin4o's Avatar
    Quote Originally Posted by Seselis5 View Post
    No way with diagnosys...
    BTW, there is not BSI.
    bobolin4o's Avatar
    Quote Originally Posted by icezero2010 View Post
    also 794b8
    The first 4 x30000 not work.
    Anyway, the bus is not here, i have a damos from Stilo edc15c7, will dig in it...
    Thanks to ALL!
    Aug 2012
    Thanks to ALL!
    if this not work is the flash speed limiter not relevant 2 solution how u can do read eeprom :-)
    second solution check if trq by gear is in the ecu set the trq to zero at this rpm you will
  10. #9
    bobolin4o's Avatar
    Gear dependent TL are only for 1 and 3 gears - tested.
