oke here is how to
Make sure engine is running !!!
In Developer mode you need to go to Entwickelingsdaten - > ansteueringen -> Gesamstliste aller Ansteuerungen
to see how many times brake has been pressed there is a line that says: Bremsenzahler (DJ_GetBrLive)
then 1 line down there you see Bremsenzahler aktualisieren und Lebensdauerzahler F neu berechenen -> click it !
Parameter uINBR = 0
then click F3
1 line down Bremsenzahler auf beliebigen Wert setzen (DJ_SetNBr) -> click it
Parameter uINBR = 0
then click F3
then scroll down untill you see the line's :
Lebensdauerzahler F neu berechenen (DJ_CalcLiveTime)
Parameter uINBR = 0
then click F3
Lebensdauerzahler F neu berechenen und schreiben (DJ_BuildAndWriteF)
Parameter uINBR = 0
then click F3
Log out of SBC !!
log out of verhicle !!
let engine run at least 10 minutes or drive at least 10 minutes
If no coils are damaged , SBC fault code is not AKTUEL nomore
If you think this would help you
Please dot not forget to click THANKS
