Page 5 of 5 FirstFirst 12345
Results 61 to 71 of 71
  1. #61
    Top Poster Grover2000's Avatar
    Sep 2010
    Question
    Hi can any fellow member who has a link with MB, advise if SBC units are still being replaced for free?
    Grover
  2. #62
    Mar 2013
    Usa
    you have abrites 72?if you have i can help you.
  3. #63
    Quote Originally Posted by wiseman View Post
    I've followed the procedure as it should and read the brake counter, was 466000 and after I completed the procedure it is 0.
    But brake service visit work shop still appears and only fault code is service threshold reached c235a,
    Have I missed something r done something incorrect, I did drive for 10 mins also
    I have same fault code on my w211 C235A, I make brake counter also 0 zero, but still that fault keep on.
    Any solutions?
  4. #64
    wiseman's Avatar
    Quote Originally Posted by coolis View Post
    Any solutions?
    Still same with me too at the moment
  5. #65
    garagetech's Avatar
    Oct 2008
    Any solutions?
    Change abs unit
  6. #66
    Hello
    I have W211 with C2498 DTC in SBC system.
    I read eeprom with AVDI and try to repair (with AVDI Dump Tool) but without succes. After eeprom programming DTC C2498 is still active.
  7. #67
    garagetech's Avatar
    Oct 2008
    Default Help! Is it possible to reset the warning light of Sensotronic Brake Control ...
    Do u have star mb? What fault r coming up now
  8. #68
    Yes. i have star mb and I try 'famous' procedure with dev mode. No luck like AVDI too.
    Fault is only one: C2498 and is still active.
  9. #69
    garagetech's Avatar
    Oct 2008
    Quote Originally Posted by carmelasse View Post
    http://mhhauto.com/Thread-Mercedes-SBC-Unit-c2498-fault
    Check this
  10. The Following User Says Thank You to garagetech For This Useful Post:
    carmelasse (9th July, 2014)
  11. #70
    garagetech's Avatar
    Oct 2008
    If it is the sbc unit
    Connected to the STAR diagnostic system, the fault code C2498 will show the fault code description ?Service Threshold Reached? as a current & stored fault code. This code cannot be erased without replacing the system.
    Common Part Numbers:
    Mercedes Part Number ? 005 431 0012
    Mercedes Part Number ? 005 431 0612
    Mercedes Part Number ? 005 431 3412
    Mercedes Part Number ? 005 431 7112
    Bosch Part Number ? 0265 250 067
    Bosch Part Number ? 0265 250 065
    Bosch Part Number ? 0265 250 077
    Bosch Part Number ? 0265 250 092
    Bosch Part Number ? 0265 960 025
    Bosch Part Number ? 0265 960 012
    Rather than replacing the unit with an expensive new part or even replacing with a second hand part (just waiting for it to fail).. we can remanufacture your existing unit and reprogram the Sensotronic Brake Control (SBC) control module to increase the service life expectancy of the unit. This is becoming a very common problem and we?re able to carry out full repairs to these units and offer a very competitive fitting rate.
    For more information & a quote, call
    0871 2887 666.
  12. The Following User Says Thank You to garagetech For This Useful Post:
  13. #71
    I'm not going to play in the exchange of motor brushes or canister pressure.
    Buy functional SBC and will end issue.
    Thank you for your help
