Tr pin code 3WG9
hello
Please can you help me with code for Lexia...i need code to configure BSI
I have code 9GW3 but Lexia ask me 5 digits code...
Dump from BSI:
dump_bsi.rar
Tr pin code 3WG9
Professional bmw key service cas 3/3+ 4/4+ repair = reset ews egs 8hp = 6hp-egs19d
5digit code : 03114
doctore (16th June, 2017)
This code is using when change configuration in bsi-citroen. For maching you need immo(pin) code-4 digit.
juggleres (7th January, 2018)
Thank you very much!
I bought a BSI+ECM+ign. set and I know the VIN of the donor vehicle. I can change the VIN in the BSI. If I change it the PIN code will not change, becouse PIN is in the ECM immo and it is originate from the first cars VIN. (So if the donor car has not the original ECM I could not use the donor's PIN from VIN.) What should I do? Buy KESS/KTAG or is there any similar solution?
Many thanks!
i have similar problem. i bring bsi, ecu and ignition from another car, te car started ok but folding mirror, fuel flap and rear windows are opening when i start the car. i try to make configuration with diagbox but did not work. higth frequancy key remote is not working as well. i need help for the bsi to work is this car. They send me the bsi from outside my country i think they send me bsi from citroen c4 and my car is citroen c4 picasso.
hello
i have the same problem with Lexia...i need code to configure a new BSI siemens e02
I have code 4 caracters but Lexia ask me 5 digits code...
thanks a lot
Dump from BSI:
Loock at post #3
This is the current topic for me in 2022.10.
508 9HD 1.6 HDI_SID807_BR2 ( 19 Faults )
today Subaru Forester 1999 sync. A pair of H44H and F93C46 is required.
A topic that interests me
yvesdu56 (20th November, 2019)
Thank you very much for the quick response
i ll try this afternoon
