Results 1 to 3 of 3
    Dec 2012
    Default help kess v2 marelli 6f3 block
    But i'm trying to figure out why my kess v2 blocks marelli 6f3 gpunto 75 cv
    After I write the file, it says the writing is done correctly, Turning the picture I do not feel pump activate, I try to write insect code with the kess ... but after no longer the ID....
    I recover the ecu with ktag, immo off partial, and fix flash on small part
    everything works
    I try to write flash with kess until the token ends, but once it just does not block .... is it a cecksum error that makes the tool?
    Are the hardware components the problem? I would not change for anything
    Some help to fix it, it's scary to use it like that
    thank you
    Dec 2012
    Can not you tell me any advice? If I can fix it by doing hardware reworks or need more thanks
    Dec 2012
    No one can fix the problem, the tool fails the checksum
