tr to use zedbull and effi 2.7.2
93C86, 8 pin, 2048 Bytes
Ford: Explorer 2007>
Transponder Type: JMA TPX2, Silca EH2
Transponder is ready to start the vehicle
hi got problem with make keys for this car cent program keys now is 0 im delete it no problem b ut cant add i try ids x100pro zed full and nothing i read memory 93c86 maybe some one can help me vvdi2 dont recognize this file i download from difrent car and vvdi2 recognize without problem pls any help
P/N 7L2T-10849-AE
SVA P/N A2C53212259
ford explorer 93c86 ori.rar
Be yourself; everyone else is already taken.
Professional bmw key service cas 3/3+ 4/4+ repair = reset ews egs 8hp = 6hp-egs19d
dyzio (22nd June, 2017)
i try on vvdi2 and tango same thing dont have effi
if you have zedbull mini or big downloads effi from dk
ok so i got this and i need pg4 from key 1
zwrot klucz nr1.rar
pls help
Last time i've got also problem with explorer sport trac. Reason was week immo antena. Place chip more near ignition lock was solution.
now i got this
2 keys ids see no problem bot 2 dtc
u2510 in IC
and P1260 in pcm
i make learning ic and pcm and nothing car still not work
but immo control go off no bliink
and after learn ic and pcm dtc still same
Try "parameter reset" ?
ok problem solved car run again thanks all for help
usually its bad antenna tHat causes your problem.
What was solution?
I have same problem on 2007. After changing miles on c86 chip needles stop working and cluster started to smoke and now no display and it don’t start. How to fix it?
You shorted something out. You will need to do some diagnosing to repair it, but it may be easier for you to just replace it if you do not know much about electronics.
I bought exact same part number. But now when I try to turn on theft light blinks fast. How to bypass theft light? Thanks
Reprogram the PATS, but you will need a good scantool and two keys.
narkeleptk (12th October, 2019)
