Results 1 to 9 of 9
    Duracell2's Avatar
    Apr 2017
    Default Is it possible to unlock ID48 Megamos Magic 2 with Effi and Zedbull mini clone?
    I tried the option in Effi (173 modules) "Unlock ID48" but It gives me error 9.
    I am using mini ZedBull clone.
    Had someone ever successfully done it ?
    Any other method beside Effi and Zedbull ?
    narkeleptk's Avatar
    May 2017
    USA
    yes it usually works with type II ones tho its been a lmg time since Ive had effi open. Perhaps my memory is off.
  3. The Following User Says Thank You to narkeleptk For This Useful Post:
    Duracell2 (28th June, 2017)
    P&D's Avatar
    CN900 unlocks them ........I think Zedbull clone will work with zedbull software v5.08
  5. The Following User Says Thank You to P&D For This Useful Post:
  6. #4
    Hungary
    Quote Originally Posted by P&D View Post
    Yes. The v5.08 can unlock the locked magic II transponder .
    https://youtu.be/4GsRCnVDZ0U
  7. The Following User Says Thank You to hbfj For This Useful Post:
  8. #5
    Duracell2's Avatar
    Apr 2017
    Have already tried with Effi 100/173 and ZedBull 5.08
    Getting "error 9"
    maybe the transponders are poor quality. I don't know.
  9. #6
    jakesman's Avatar
    Oct 2013
    Bethlehem Southafrica
    in my experiance if it is ID 48 for CAN bus cars , zedbull and effi did not unlock it but older cars using same ID48 but not CAN bus cars it unlocks and reprogram it no problem
    Ask a dumb question and become wise for the rest of your life, but act wise and stay dumb
  10. The Following User Says Thank You to jakesman For This Useful Post:
  11. #7
    Dec 2018
    so did any1 unlock it ?
    i have same issue
    there is an unlock option in the zed bull software, but will it wipe my key\remote and make it unsusable ?
    cuz i only have one1
  12. #8
    narkeleptk's Avatar
    May 2017
    USA
    Only one way to find out.
  13. #9
    Oct 2014
    Netherlands
    Unlock an ID48 must be done with a pincode.
    I remember Effi software is using 2 different pincodes, but if both aren't valid then you're out of luck.
    But if you write some software you can easily brute the right pincode, it will just take some time ...
