Results 1 to 7 of 7
    Mar 2017
    Default please need disable the code df569 renault master III
    ANY ONE CAN DISABLE DF569
    RENAULT MASTER III
    EDC17C11
    THANKS
    Mar 2017
    THIS IS THE FILE
    THANKS
    Mar 2017
    please help for disable the dtc
    mihaiservice's Avatar
    http://www.quick-tuning.com
    Such dtc are related to boost pressure ! better are to find the reason why its lose boost pressure !
    Only dtc off will not bypass limp mode.
    Full WinOLS user
    Custom ENG/GER OLS file for ​ Tune /DPF / SCR / EGR / TVA / VSA / DTC and more...
  5. The Following 2 Users Say Thank You to mihaiservice For This Useful Post:
    mecafrigo (27th June, 2017), pike (27th June, 2017)
    Mar 2017
    because of code the ecu go to limp mode please off the dtc if some one can do
    its only a sensor for boost pressure after dpf off start the problem
    Jun 2017
    Dtc will be deleted but limp mode will be ON
    Sep 2012
    POSSIBLE YOUR FILE DEFAP IS NOT OK.... REPLY YOUR FILE ORI AND TEST
