Results 1 to 3 of 3
    Apr 2016
    Italy
    Default Ford Focus 1.6Tdci 80Kw Edc16c34
    Hello ,
    I've problem with a Ford Focus 1.6 Tdci 80 Kw with fap fillter that has problem with cerine liquid, the fault code present are :
    - P1922-00 , P1922-60 with Ford diagnosys and are not erasable .
    Could someone help me to solve this problem.
    In attach ori file .
    Thanks in advance .
    here there
    My friend make all resets with diagnostic equipment. Refill FAT in FACM module. MAke DPF OFF, remove plug from FACM module unde backseat. Job done. If you want this solution just say and i can make you dpf off
    Jan 2018
    Hi how can this be done please? Thanks
