Results 1 to 11 of 11
Thread: SID807
    Jan 2017
    Default SID807
    Help !!! Need help PEUGEOT3008 SID807 , removed the DPF and now after the car travels 3km dumped in a car accident !!! Can someone look at the dump, where could I go wrong ???
    Https://yadi.sk/d/PzsMQ4ff3Kacz6 ори
    https://yadi.sk/d/R-gfHXm03Kad4Z FAP нет
    Jun 2013
    EU
    WTF!! This is english only speaking forum mate, at least use a translator.
  3. The Following 2 Users Say Thank You to morgano For This Useful Post:
    pike (29th June, 2017), vitolek (28th June, 2017)
    Jan 2017
    help friends
    Babos's Avatar
    Mar 2012
    It is not solution but shite
    buy good solution and relax.
    как то так.
  6. The Following 2 Users Say Thank You to Babos For This Useful Post:
    morgano (29th June, 2017), pike (29th June, 2017)
    rj22's Avatar
    Your file dpf off
  8. #6
    Jun 2017
    Let me know if not solved i will help you
  9. #7
    pike's Avatar
    Sep 2013
    Hi.
    How was the original file received?
  10. #8
    Jan 2017
    thank you all!!!everything had to be redone and the car drove away
  11. #9
    Jan 2017
    [QUOTE = rj22; 3064108] Ваш файл dpf off [/ QUOTE]
    thank you!!!but your dump is not working
  12. #10
    rj22's Avatar
    What happens, why does not work?
    Before writing, do DPF exchange after OBD
  13. #11
    Jan 2017
    [QUOTE = rj22; 3064935] Что происходит, почему не работает?
    Прежде чем писать, сделайте обмен DPF после OBD [/ QUOTE]
    I tried to fill your dump.burn errors including the level yolisa
