    Oct 2011
    Default Xtrend ET-9200 - Tuner failed!
    Hi, I would be very grateful for your help regarding a problem with my Xtrend 9200 receiver.
    Since last week, upon startup, i am unable to receive any channels. I have a 'Tune failed!' message appear
    on screen. After switching off then on again i get the same problem so i am unable to receive any channels.
    The same problem exists after i flash different images.
    On a couple of occasions having left the receiver on a channel where the Tuner A indicator appears in green (not yellow)
    i have found after many hours that the channel is received. Unfortunately once i switch the receiver to standby or sometimes
    change channel i get the 'Tuner failed!' message again. This problem continues and i cannot receive any channels now.
    I read there is an address somewhere in Germany where i can send the receiver to be fixed. Does anybody know is this is correct and what the address is please?
    Many thanks if you can help me.
    digicon's Avatar
    I would not bother sending it to Germany i had an old ET9000 model same as the 9200 apart from cosmetic differences, They basically sent it back as parts are no longer available.
    Time to move onto a different receiver
  3. The Following User Says Thank You to digicon For This Useful Post:
    satlover276 (30th June, 2017)
    Oct 2011
    Okay i understand.
    Nov 2008
    Hi There
    I actually had this also.
    I basically in the end factory reset it and started again and it worked
    Oct 2019
    Definitely, reset it to factory settings helps in this case.
    Aug 2020
    It's a rather old and cheap tuner. I would just ditch it and buy a better one!
