    WinWoj's Avatar
    Jan 2012
    ECU City
    Default VW Golf 5 EDC16U34 EGR off please 90HP
    Hello, i receive MAF faults P0101 when airflow request not the same as actual. I don't want to clean it soon, so i would like to switch egr off. Please help.
    Also P1592 Altitude / Boost pressure sensor sometimes decrease power, if possible, please off it. Regards.05-03G906021KG.zip
    May 2016
    Try it egr off dtc p1592 off.
  3. The Following User Says Thank You to naprawa5 For This Useful Post:
    WinWoj (30th June, 2017)
    WinWoj's Avatar
    Jan 2012
    ECU City
    (English forum) thanks, but file name has 'dpf off' i don't want to switch dpf, but egr.
    May 2016
    (English Forum) Nazwa dzięki, ale plik ?dpf off? nie chcę, aby przełączyć DPF, ale EGR.
    DPF off golf 5.
  6. The Following User Says Thank You to naprawa5 For This Useful Post:
    WinWoj's Avatar
    Jan 2012
    ECU City
    Friend, i see it is switch only? No any maps needed? Unplug any valve not necessary? Just write this not checksummed file and get never work, yes?
  8. #6
    Quote Originally Posted by WinWoj View Post
    This should be ok.
  9. The Following User Says Thank You to darkman30 For This Useful Post:
    WinWoj (3rd July, 2017)
