Results 1 to 15 of 21
    Default Mini R56 95128internal control unit fault
    Can anyone assist with a dump for auto liv airbag control unit. Part no is 65.77 3454346 -01. It says internal control unit fault. For some odd reason i can no longer post on DK ive asked admin to assist but no luck so i cannot upload. Is there anyone who can assist please?
    Sep 2011
    south africa
    Default mini dump
    mini r56 95128.rar
    ive attached file from friends
    pc
  3. The Following User Says Thank You to rambit For This Useful Post:
    elitricista (7th August, 2018)
    Anyone have a working dump for this unit please? I dont want to just try another Please
    Hi guys
    I cannot find a replacement with the same number. I have attached the file also 95128 from a donor airbag unit also Auto Liv. The part number is 65.77 3428715-01 hw 07 bmw no 313428715015
    Can someone please assit to clear this unit?i get fault
    93B0 ACSM/MRS Head airbag driver present
    93AC ACSM/MRS Side Airbag Driver
    Is this crash data or just 2 circuits that need to be bypassed because the vehicle is not fitted with this type of system.
    Please help
    dragon100's Avatar
    Jan 2012
    From land of milk and honey
    It is not crash, join resistors 2,2ohm or 3,3 ohm to the srs unit where should be airbags (because u use file from other car with other coding and equipment) ...
    Scripts for Multi-PROG
    Best regards.
    Dragon
  7. The Following User Says Thank You to dragon100 For This Useful Post:
    rambit (11th July, 2017)
  8. #6
    dragon100's Avatar
    Jan 2012
    Try this file ...it was tested , ori file was internal error and I did ok ...
    Best regards.
    Dragon
  9. The Following 3 Users Say Thank You to dragon100 For This Useful Post:
    ascotauto (13th July, 2017), Astrator (5th September, 2023), bicoinjecao (2nd June, 2018)
  10. #7
    Aug 2015
    Please Brother the file has Control-unit fault 93d7, please helpe me.
  11. #8
    dragon100's Avatar
    Jan 2012
    Your repaired file.
    Best regards.
    Dragon
  12. The Following 2 Users Say Thank You to dragon100 For This Useful Post:
    automotrizVIP (2nd June, 2018), mauan diag (12th September, 2018)
  13. #9
    ThiagoArgentino's Avatar
    May 2016
    Brazil
    Hello guys !! Can you help me with this Airbag?
    Solutions in the area of automotive coded keys, all automakers.
  14. #10
    dragon100's Avatar
    Jan 2012
    Your repaired file.
    Best regards.
    Dragon
  15. The Following User Says Thank You to dragon100 For This Useful Post:
    ThiagoArgentino (15th June, 2018)
  16. #11
    May 2016
    Brazil
    Quote Originally Posted by dragon100 View Post
    Your repaired file.
    Which password ?
  17. #12
    May 2016
    Brazil
    Worked perfectly !!! Thank you
  18. #13
    Oct 2015
    Lithuania
    Helo
    I need help airbag mini with internal foult. Control unit Autoliv 65.77 3428715-01 HW07 insaid eeprom 95128
  19. #14
    Jun 2015
    Default can u help me with tha same error
    mini 65.779812297-01 have 93d7 internal fault unit
  20. #15
    Apr 2024
    Türkiye
    Default mini cooper airbag 65.77 3454346-01 airbag crash help
    bmw nr:313454346014
    610067400n
    hw25
    crash clear dtc 0093d7 internal error
    eprom 95128
