Results 1 to 4 of 4
    EU
    Default Vectra C 1.9 CDTI EDC16c9 DPF
    can somebody help with good solution for dpf off EDC16c9 0281011915 Opel Vectra 1.9CDTI ?
    Thanks in advance.
    vectra edc16c9 0281011915 ori.zip
    immokill's Avatar
    Jun 2009
    UNIVERSE
    HERE YOU GO
    Here to HELP!
  3. The Following User Says Thank You to immokill For This Useful Post:
    ollync (6th July, 2017)
    EU
    Quote Originally Posted by immokill View Post
    HERE YOU GO
    Can you make EGR off too?
    The DPF was totally clogged, no exhaust gasses could pass through it, i removed the filter, cleaned everything, new turbo is also installed because the old one was shut, but now i have no power till 2500-2800 rpm and i get always P2279 - Intake Air System Leak Detected.
    I checked for leaks at the intercooler and intake system and cold not find anything so i suspect EGR is not closing totally and i want to blank it out.
    EU
    Never mind. Problem solved. Thanks again.
