Here is file!
Here is file!
Triton74 (17th June, 2019)
I need to blank EGR at first. But in the same time I want to increase power. Especially the torque.
Thank you. I will take a look a little bit later.
For the rest I only need the maps adresses and there fonctions.
Hello Mariobozze,
Thank you very much for the file.
I am glad to see that you went to my rescue.
For the next state, I want to increase the power.
Can you tell me on which maps I have to work?
Or can you edit the file for me?
Greetings
If i helped, don't forget push thanks + rep
[QUOTE=mancioks;3602157.................TE]
I have read this section for a while. My file contains other map tables identifications.
I think the structure of my file was used only for a short time (vehicle production).
If you tip the Bosch or the Opel serial numbers on the web, you will find nothing.
Hello!
Here is Tuning file!
Pass = same like EGR off
Please push also thanks on this file
greetins :-)
Hello Mario the Boss,
I have written the ECU with your file this morning and tested the car with Egr unplugged on mountain roads for about 20 Kms.
You have made really a very good job.
My first impressions are:
The torque is really present, in some cases I can put a higher gear at same speed.
The accelerations are more progressive. Before I had impression that they where steps in accelerations. This results to a smoother drive.
There is a lot of lesser smoke. I think that is the result of EGR Off
The car stereo works better. I'me joking.
I will let another report after long test drive (flat and high roads) and after I emptied 2 or 3 full tanks. With fuel consumptions.
You're really a great guy. Without you I was totally lost.
Thank a lot.
hello I would need the pass thank you
is very easy for unplug and remove , i put the picture for you remove in hex mode ,,, need unplug
WHIT MAPS
1. In the two hysteresis cards, set all values to zero.
2. We increase the value of 450 to the maximum value and lower the value of 900 to the minimum value (zero value).
3. The error mask should be 0, where there is an error 0400.
dodog (7th September, 2022)
pgs16 off 1.jpgpgs16 off 2.jpgtoma que te lo he hecho alguien no lo entiende si ck y las fotos
y sisn programas solo con un hex editor
Fec001 free for you AHORA VAS Y LOS CASCAS
saab 2.2 y22dth 12992763.rarCan you send me your mod st2 and egr off files or mod my file saab 9-3?
