Page 1 of 3 123 LastLast
Results 1 to 15 of 31
    Fec001's Avatar
    Default Zafira PSG16 EGR off and tune
    Hi!
    I need EGR off solution with disconnected plug because EGR is broken and if possible some power increase or mappack because I didn't found smoke limiter, boost limiter and SVBL.
    Thank you!!!!
  2. The Following User Says Thank You to Fec001 For This Useful Post:
    jnsvcs (4th March, 2020)
  3. #2
    Jun 2013
    EU
    Here your file egr disconnected. Guess the tune maps you look for are @
    0x16E50 (10x12)
    0x16F40 (2x1)
    0x16F44 (16x9)
    Those turbo related, about smoke can't help.
  4. The Following 3 Users Say Thank You to morgano For This Useful Post:
    Fec001 (7th July, 2017), klonone (30th October, 2019), leotdx (27th December, 2017)
  5. #3
    Fec001's Avatar
    With egr off file, car starts only for a second, then shut off and I have 2 dtc:
    P0335 crankshaft position sensor circuit maldunction
    P0340 camshaft sensor circuit malfunction
    EDIT:
    Solved, it was wrong connection at crankshaft sensor........
  6. #4
    Jun 2017
    london
    post file when i can delete dtc for you
    AVDigitale's Avatar
    Apr 2017
    Best Place in the World!
    egr off with disconected plug and dtc off no cheks calculate with your tool
  8. The Following 2 Users Say Thank You to AVDigitale For This Useful Post:
    danielif (8th April, 2023), klonone (31st October, 2019)
  9. #6
    Feb 2019
    France
    I have the same problem.
    Can someone help me to make the file myself?
    Thank's
  10. #7
    Aug 2018
    Austria
    Hello!
    So whats problem Triton74?
    Greetings
  11. #8
    Feb 2019
    France
    I want to make an EGR and DTC Off. And at the same time I want to increase torque.
    I have winols, Ecm titanium. And I know someone ho can lean me MPPS V18 clone.
    I don't know the way to disable EGR.
    I search someone ho can explain me the how to.
  12. #9
    Aug 2018
    Austria
    If you want i could send file where is EGR off and Tuning Stage 2 original and modify there you see how it workes! (With disconnect egr plug)
  13. The Following User Says Thank You to Mariobozze For This Useful Post:
    Triton74 (22nd February, 2019)
  14. #10
    Feb 2019
    France
    That is very nice from you.
    What do you mean to stage 2? I have a Zafi, stock, with 125 Ps. (HW: 0470504202)
    How much Ps and Nm with your file?
    How can I do to compare your files?
    Thank you very much for your help.
  15. #11
    Feb 2019
    France
    Hello Mariobozze,
    Can you send me your files?
  16. #12
    Fec001's Avatar
    I lost previous EGR off files and pass. Can you make EGR off in this file again with disconnected EGR connector and DTCs off (P0400) without limp mode.
    Attached same file. If someone give me a hint about smoke limiter that would be great.
    IQ limiters are correct?
    0D0E0 8x8
    0D17C 6x6
    0D228 8x8
    0D2C4 6x6
    EDIT:
    EGR solved.
  17. #13
    Feb 2019
    France
    I'me back again. I have finally bought a MPPS. And I have extracted file today.
    I need to know how to make EGR Off.
    Water-cooling intake is broken and now I have sometimes P0400 DTC.
    I also want to increase power.
    In attachment the Original file.
    Here are the specs of my car:
    Bosch Hardware Number: BOSCH0100Bosch Software Number: 24451343 KB
    Opel Software Number: 0470504202
    ECU Type: PSG16
    Engine Type: Y22DTR
  18. #14
    Feb 2019
    France
    I have tried to open it with winols. It found me 97 potential maps.
    I don't know on which maps I have to work for power increase.
    And I don't find where are located the values to change for the EGR Off by hysteresis.
    Really need help.
  19. #15
    Aug 2018
    Austria
    Quote Originally Posted by Triton74 View Post
    Really need help.
    You want only EGR off or also Tuning?
    Greetings
