Results 1 to 8 of 8
    johak's Avatar
    Default Astra H dpf egr edc16c39
    Hello everyone,
    can anyone help me to remove dpf and egr on this ecu
    Astra H edc16c39 1.9CDTI 100hp sw 389374 read in bdm
    I need a 100% solution because the car is far away.
    Thanks in advance
    May 2012
    test this file and report ok
  3. The Following User Says Thank You to kamel2003 For This Useful Post:
    johak (7th July, 2017)
    johak's Avatar
    Thanks but i need a 100% solution
    The car is far away
    Is this dpf and egr off?
    Jun 2013
    EU
    Quote Originally Posted by johak View Post
    The car is far away
    Free file in less than an hour i guess is worth the test. Have received a file in professional response time. Maybe you should test the file and be happy or buy it elsewhere from a prof tuner so you are sure is 100% solution.
    johak's Avatar
    Thanks kamel2003 for the lost time
    I need the DPF and EGR off
    I can not test so quickly
    So I'm looking for a tested solution.
    If anyone can help ... thank you
    johak's Avatar
    problem not yet solved
    If anyone can help
    ivanmihov's Avatar
    Nov 2016
    Europe
    Tested Solution DPF OFF + EGR OFF
    Pass in PM
  9. The Following User Says Thank You to ivanmihov For This Useful Post:
    johak (10th July, 2017)
  10. #8
    Nov 2011
    Hello everyone,
    Thanks in advance
    thanks for the file
