Page 1 of 2 12 LastLast
Results 1 to 15 of 22
    Chiclana
    Default I need help with Megane 1.5 dci map
    I have a Megane 1.5 dci 80cv.
    I read the map with galletto but I don?t find the software to change it, because the ecm2001 don?t have the driver.
    I look for the driver and find a lot of but not that driver
    This is my map
    http://www.megaupload.com/?d=USWYORJD
    Sep 2009
    Send me the file and i make that.
    Lacko_1
    ecm version?
    Dobermann's Avatar
    Germany
    Quote Originally Posted by velaneando View Post
    make your own driver !!!
    post the ori file please
    Chiclana
    Default Here is the file
    Quote Originally Posted by Lacko_1 View Post
    Lacko_1
    ecm version?
    The Ecm version is 5.1
    and this is the file
    MEGAUPLOAD - The leading online storage and file delivery service
    Chiclana
    Quote Originally Posted by Dobermann View Post
    Please, can you tell me how make my own driver.
    Chiclana
    Please someone than help me,
    thanks so much
    Aug 2009
    This is my map
    This file is a partial reading of the flash, only the zone maps.
    Alientech drivers, need to complete reading the flash to work. (for this reading, does not serve any driver ecm)
    Regards.
    Dobermann's Avatar
    Germany
    Quote Originally Posted by gezame View Post
    Regards.
    gezame is right !!!!
    thats ecactly the same that i told you !!
    you must read the full file of this ecu !!
    Chiclana
    I think than the file it?s perfect,
    I try to read another time and is the same.
    I?m thinking than my galleto is out.
    Jul 2010
    File potenciado con CS OLS powerinyeccion.
  11. #11
    Jan 2010
    Default rail pressure
    this post and the old. I was watching the maps. map rail pressure source does 1400bar and this modification is to 1700bar. the pump can handle?
  12. #12
    waldi1979's Avatar
    Dec 2010
    1400 -> 1470
  13. #13
    Jan 2010
    Default rail
    sorry you have reason. I must be drunk
  14. #14
    Jan 2010
    Default map
    hello can you tell if you know what map is this? does it have to do with pressure sensor turbo?
  15. #15
    Jul 2010
    ALGERIA
    limiter turbo presure map
