Results 1 to 9 of 9
Hybrid View
    May 2011
    Default how safe is it to use digiprog 3 clone on 2008 5 series bmw e60 to change kms
    hi all ive been trying to sort a 2008 5 series e60 bmw for a friend and change mileage
    my bmw multitool wont do it and i told him to come take car back
    i do have a clone digiprog3 but im not always keen to use it
    is it safe on the cas3 on this car
    i can do the cluster no problem just dont have any good tools to do the cas
    except this clone digiprog 3
    Cllau's Avatar
    Mar 2017
    where friends need me
    mate, clone does not work in CAS only the genuine does with HC-12, from 2008+ will do by OBD with CAS3 DIAG. Buy R270 programmer will do the CAS3 for you.
    Oct 2010
    You can try with Digi ,I did a couple of them with CAS3+ and all was fine .
    Wysłane z mojego HTC One A9 przy użyciu Tapatalka
    May 2011
    i also have the bmw multitool with the cas3 adapters
    but it would connect to cas but not read it
    i can atleast use the cas connectors for other tools i hope
    May 2011
    ok i will only do it if friend will pay for new cas if it stuff it up,
    i want to buy an r270
    is there photos on where to solder the wires or is it all in the instructions
    i also see ther eis an r280 programming tool for bmw
    is it worth getting thst instead or just use the r270
    thanks to all for the info
    Cllau's Avatar
    Mar 2017
    R270- Very easy to use and comes with instructions and pictures.
    Cllau's Avatar
    Mar 2017
    Default R270
    Quote Originally Posted by sideshow View Post
    R270 instructions...
    May 2011
    thanks guys i think i will order oen of those tools from china
    i just tried my digiprog 3 clone and it does read the cas but it doesnt recognise the file
    i got the same problem with my bmw multitools connects to cas but unknown system error
    im hoping this r270 will recognise it
    maybe its too new a bmw being late 08 e60
    thanks guys for all the info
    Dec 2009
    R270 will definitely do it you only get unknown version trying obd
