This version included both install and Portable version 9.6.6.3300, key give in text file, you can use it for registration.
UltraISO Premium Edition 9.6 crack key has a simple interface, easy to use. If you have ever used winrar to extract the rar file, .zip then UltraISO also compare the ease of use.
Main feature of UltraISO Premium Edition 9.6 crack key:
- Edit the ISO image file
- Can directly extract files and folders from ISO image file
- Add/delete/create new directory/rename ISO image file in the content
- Create ISO file from hard disk document
- Create CD/DVD image from CD/DVD-ROM, keep the boot setup
- Handle the information of the boot disk, you can directly add/remove/extract boot image of the ISO image
- Supports almost all CD/DVD image formats already know (. ISO,. BIN,. IMG,. CIF,. NRG,. MDS,. CCD,. BWI,. ISZ,. DMG,. DAA,. UIF,. HFS...) and can convert them into the format of the standard format is ISO support.
- Ability to directly set the hidden attribute for the file/folder
- ISO 9660 support Level1/2/3 and Joliet extension
- Automatically optimizes the ISO image file structures to earn maximum savings amount
- Support to open the image files through 1 double click
- Windows user interface easy to use.
There are many rich add-on tools, you can create a boot disk at All-in-one, manage image files from CD/DVD or even create virtual drive ...
