Hi, I have a Chinese clonic interface 812.4 beta, if I use Vag Com version 908, it will be blocked by the Vag com version 908.?
Yes I think so.
yes you will block it
if you have clone (a good one) and if you use vcds908 you will get this message: "ross-tech interface not found! Interface: not found!". in that case you can downgrade your installation of vcds to version 805 and your cable would work. BUT if you have some of cheap chinese crap interfaces, you will blown it!! so, be careful!! because you don't know what you have, my advice is NOT to try!
any1 recommends 812.4 good chinese clone?
buy a serbian cloneversion 908 is availibile for some time
Perhaps this one : Spaske's VCDS 908
I'd be a bit worried about letting swedish chef near that interface in case the warranty gets bork'd
On many sites available.
Including on our site
Works great.
I give 2 years warranty for mine, hardware identical to original very good quality, tested pcb, SI chips on K lines, 16v8BQL ,no overheating, . I make it myself. Only thing that can destroy it if you go on internet with that pc... export price is smaller then on site, but still much more then chinese, free delivery for Europe![]()
spaske,
can you explain what you mean by "destroy it if you go on internet with that pc"?
Can it be fixed if it is destroyed?
Also if new software after 908 can this be installed and working?
