Load the original file , and reset the filter and oil , read flash and send a forum.
VOLTA not good work
Hey.
Hawe some problems with DPF remove
ECU:
FPT (MM) MJD 6F3.P5/HW03P/3442-P568
G PUNTTO 1.3 SDE 90 HP DPF
CAR:
Fiat Grande Punto 1.3 JTD 2007
Car had no DTC in ECU nut on dash was emergency recover DPF. Is live data i saw 457% of capacity dpf blocked. Someone before me cut filter but dont do ECU CHIP. Now car came to me.
I do all service functions by KTS (replace filter, presure sensor. etc.). Next i done the chip by VOLTA. Car drive normal dont smoke no DTCs present in ECU but on dash is that message that filter is overloaded.
If I help You. please say THANKS.
VOLTA not good work
..Ecu Repair ... Steering Wheel Repair ... Dash Repair ... AirBag Repair .... that Bad LiFe ...
marek128 (17th July, 2017)
yeach mate im done already digi kaos seems chrach or something cant log in. KTS dont reset properly DPF im done AUTOCOM and after write off file. All ok.
P.S. Cant upload any file seems DK hawe some bug?
