I dont now why I cant upload new file.
If someone can help I will send dump on mail.
HI to all.
I need some help, and I hope someone specializing in BMW will help.
I have in garge BMW x5 2002 3.0D AT with DD4 ecu
SW: 1037351761
and on hot engine somtime engine oil blink on dash.
When start engine speed go to 850 and after 10 s falls to 670.
Engine is after oil pomp change and complete repairs .
If someone can pull up idlle speed to 750-800 it will be great.
Thanks for any help.[
ATTACH]463920[/ATTACH]
use the basic uploader same place as the normal uploader hard to miss tho
marmaro (17th July, 2017)
That engine will not have a long life if oil lamp still are blinking,you have to check again the timing and oil pressure with a gauges!
Are a simple and good engine,all you to do are to remove all 6 injectors and use one long screwdriver !
Full WinOLS user
Custom ENG/GER OLS file for Tune /DPF / SCR / EGR / TVA / VSA / DTC and more...
Now there should be 800.
marmaro (18th July, 2017)
Idle speed up is definitely no solution for your problem. Check , like was said, oil pressure with gauge . When warm at idle it should min 7 PSI that is approx 0.5 bar . If it is so, replace oil pressure sender. If not, check oil pump, bearings, etc that is related to oil pressure. Only if you want that your engine will live a long life.
Thanks .I will try and raport.
Thanks for reply.
In this engine it should be 750rpm +-100 on idle.
Here is -100, and I think pull up to 750 it should not be problem,and It can temporarily prevent engine damage.
Thanks to
waldi1979 help me and increase speed to 800 rpm on P (automatic transmition) but when set to D speed fall down to 670
Maybe someone have solution to me , or when member waldi1979 be online can help me .
BR
test and report rpm 800
Tuning Cars and Trucks, Immo off , DTC delete, DPF off
Try this file.,
marmaro (19th July, 2017)
